configure cdp frequency
configure cdp frequency seconds
Description
Enables CDP on a port.
Syntax Description
seconds Specifies the transmit frequency in seconds. The range is 5,254 seconds. The default value is 60 seconds.
Default
60 seconds.
Usage Guidelines
The following command configures the CDP frequency as two minutes:
configure cdp frequency 120
This command was first available in ExtremeXOS 15.4.
Platform Availability
